SMD VM-1 LED Volt Meter! (its back!) Pics/short vid pg. 19 (new update pg 35)
the wiring would be easy. power wire to what you want to watch the voltage on (amp, batt bank, alt, distro block, front batt), remote to h/u remote, negative to closest ground. not rocket science, if you can wire an amp you can wire a voltage meter.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
A signature on the back would be cool, but having a certificate of authenticity and a XX of 100 on it with Steve's Signature would be better.
YES my order has been placed ..Too bad the code dosent work anymore :(
Did you copy-paste? If there are any spaces before or after the code it won't work. I didn't see a time limit on the code.
Yes i did and it said that this coupon was no longer available ??
I got my order in for one of these and i want to go ahead and get the wires run so when it gets here i'm ready to hook it up.
My question is would 14ga wire be overkill for this,since i already have some on hand?
Also can you tell us how it is mounted?
14ga will be fine
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
  • Who's Online   0 Members, 0 Anonymous, 1150 Guests (See full list)
