Hotdog Posted May 27, 2012 Report Posted May 27, 2012 here is what I have available for room. From headrest of front seats to headrest of second row seats 46" Wide x 30" Depth and 42" Height = 33.54ft3 Gross From headrest of second row seats to rear hatch 46" Wide x 30" depth x 33.5" Height = 26.75ft3 Gross 60.29ft3 gross volume availible. That being said my best bet would be to have them at a 45 front to back I am saying this because I have depth just not height or width for 3 together. 3 on each side, would that perform decently in this configuration. I am probably going to do this next weekend if all goes as planned I was thinking something like this.. forgive the drawing I am not very good with google sketch up 3 15's per side (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Hotdog Posted May 27, 2012 Author Report Posted May 27, 2012 6 Rockford Fosgate RFR2215 15" Power series QTS: .35 FS: 20hz QMS: 5.97 QES: .38 VAS: 9.182ft3 CMS: 2.25E-04 M/N Mms: 8.325oz BL: 12.7Tm Xmax: .53 In SPL: 89db PE: 1000w RMS I would like to do 1.5 sealed per 15 with a ratio of 3:1 unless there is a better alternative (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Hotdog Posted May 27, 2012 Author Report Posted May 27, 2012 Ok this is a more accurate representation of the enclosure. Now when tuning the loading wall you tune to resonance or Peak of the sealed chamber's? and if it is something high like 53hz how do you make a port big enough? (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Hugh G. Rection Posted May 27, 2012 Report Posted May 27, 2012 Damn that port is going to be huge. mine is 10.5x32.875 for only 2 15's. his isnt really all that big, lol im running 2.6 per sub sealed, in 1:3 ratio. Owner of BigAss Ports
Hotdog Posted May 28, 2012 Author Report Posted May 28, 2012 Damn that port is going to be huge. mine is 10.5x32.875 for only 2 15's. his isnt really all that big, lol im running 2.6 per sub sealed, in 1:3 ratio. I am looking at a ratio close to 4:1 I will probably have an odd shaped port to try and get 500 sq in of port (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Hugh G. Rection Posted June 4, 2012 Report Posted June 4, 2012 Damn that port is going to be huge. mine is 10.5x32.875 for only 2 15's. his isnt really all that big, lol im running 2.6 per sub sealed, in 1:3 ratio. I am looking at a ratio close to 4:1 I will probably have an odd shaped port to try and get 500 sq in of port just remember, the bigger ratio may get you louder, and lower, but has a narrower overall bandwidth. Owner of BigAss Ports
