412 CVX Posted May 28, 2012 Report Share Posted May 28, 2012 slot port from the looks of it. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
carlosg_313 Posted May 28, 2012 Report Share Posted May 28, 2012 (edited) only if the port was longer, there wouldnt be a problem with bracing. boxes i build without bracing turned out fine. even with a heavy level 5 and 6, there wasnt a problem. but in this case, brace would be a good idea. thanks for the idea cvx Edited May 28, 2012 by carlosg_313 Quote How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman Link to comment Share on other sites More sharing options...
carlosg_313 Posted May 28, 2012 Report Share Posted May 28, 2012 slot port from the looks of it. correct. Quote How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman Link to comment Share on other sites More sharing options...
Riley Evan Houser Posted May 28, 2012 Author Report Share Posted May 28, 2012 Is it like the Type L port on the RE box calculator? I'm sorry guys..no previous experience with these.. Quote Link to comment Share on other sites More sharing options...
carlosg_313 Posted May 28, 2012 Report Share Posted May 28, 2012 btw, i would want you to double check the measurements from in between the wheel well, and the trunk's opening. but if worst comes to worst, you got to kick that box in to make it go in there. and i think i should have the port facing up. but ill keep it like this for now. Quote How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman Link to comment Share on other sites More sharing options...
carlosg_313 Posted May 28, 2012 Report Share Posted May 28, 2012 Is it like the Type L port on the RE box calculator? I'm sorry guys..no previous experience with these.. yes, L port/slot port, same thing. but i wouldnt use RE's calculator. been using torres close to a year and been pretty good. Quote How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman Link to comment Share on other sites More sharing options...
Riley Evan Houser Posted May 28, 2012 Author Report Share Posted May 28, 2012 only if the port was longer, there wouldnt be a problem with bracing. boxes i build without bracing turned out fine. even with a heavy level 5 and 6, there wasnt a problem. but in this case, brace would be a good idea. thanks for the idea cvx My bad, I didn't see that post. That's looks good man! So would I make the box like that or like the L port? Quote Link to comment Share on other sites More sharing options...
carlosg_313 Posted May 28, 2012 Report Share Posted May 28, 2012 (edited) only if the port was longer, there wouldnt be a problem with bracing. boxes i build without bracing turned out fine. even with a heavy level 5 and 6, there wasnt a problem. but in this case, brace would be a good idea. thanks for the idea cvx My bad, I didn't see that post. That's looks good man! So would I make the box like that or like the L port? that is a L port box. lol. i would give this one a try. edit - at this point, this is the good thing about audio, trail and error, if this design does not work, there are few more to choose from. some cars like all facing to the cabin with the trunk sealed. some cars like the design i just did, some cars even like everything facing back to the hatch. im not guaranteeing it will be the best for your car, but its something to start with. Edited May 28, 2012 by carlosg_313 Quote How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman Link to comment Share on other sites More sharing options...
Riley Evan Houser Posted May 28, 2012 Author Report Share Posted May 28, 2012 (edited) Haha, my bad man.. should be a decent size box. ill make a design for 7-8 cubes before displacement, and maybe shoot around 6 cuft after displacement tuned to 34-35hz. what amp do you have? btw what car do you drive? I have a Soundstream TX1.2000D and I drive 2004 Pontiac Bonneville, and thanks man So, just use these dimensions for the build..correct? Subs on top and port towards the trunk lid? Edited May 28, 2012 by Riley Evan Houser Quote Link to comment Share on other sites More sharing options...
Riley Evan Houser Posted May 28, 2012 Author Report Share Posted May 28, 2012 Or are these subs on the side and the port facing up? Quote Link to comment Share on other sites More sharing options...
