Alright guys, got another question for all of you, I need some help with this one. If you've read my other posts you'll know that I have 2 Sundown SA15s, but I need help with my new box build. I have roughly 40"s from side to side in my trunk to spare, 19" high, and however deep that is needed. On Sundown's website it say 3-4 cubic feet tuned to 35 hz. What would you guys recommend? But I was wondering about making a box with the 2 subs and one long port under the two? Would I need to add a middle wall between the two or can I just leave it open so they both go out of the same long port under the two? Just let me know what you guys think I should do and how many hzs to tune them at? Let me hear your opinions!
depth on the sa15s is 7.5"
Team Audio Specialists
1998 GMC Sierra SLT Z71 ext. cab
Headunit: Pioneer DEH-P7400HD
Mids and Highs:
One pair Boston SC65 6.5s
One pair Boston SE75 4x6s
Two pairs of Precision power T.2 tweeters
Two pairs of ebay type tweeters (soon to be replaced)
Boston GTA704 four channel amp
RCAs: Stinger 4000 series 4 channel RCAs
Lows:
Two Sundown Audio SA-12s
Sundown Audio Saz-2500d
3.9 cubic foot ported box (full 45 corners) fully braced and resined tuned at 33hz, all before displacement
XS Power D3400 and Interstate starting battery, both under hood
all KnuKonceptz Kolossus 1/0 wire (just 1 run for now)
Big 3 done in 1/0
Audio Specialists <-----Best car audio shop in Western Kentucky/North Central Tennessee
should be a decent size box. ill make a design for 7-8 cubes before displacement, and maybe shoot around 6 cuft after displacement tuned to 34-35hz. what amp do you have?
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
btw what car do you drive?
I have a Soundstream TX1.2000D and I drive 2004 Pontiac Bonneville, and thanks man
no bracing? good luck...
wouldnt be a problem without bracing. since they are around 70lbs total.
..BUT then again, i will not be builing the box, so you are right. lol.
edit - 2x2 can be an option from top to bottom, and wouldnt change much on the internal size and tuning.
will be post final sketch in a minute.
Edited by carlosg_313
