Guy dropped his car off last night, so I had one day to build for it. He had some pretty strict ideas of how he wanted it, so I tried to work within those guidelines.
built a top plate first, he wanted a flush appearance:
Then cut out the amprack, which will house a pair of Sundown amps. Once he gets the amps in, I'll do a top plate to actually flush the amps into the rack:
Then built a simple kerfed center port box, but flushed the subs in to stick with the theme:
Then cut out the top plate for the box to fit into, there was no way it would have went in in one piece, so I put the box in first, then slid the plate in over it:
Then carpeted everything:
Just waiting on him to buy the amps, then I'll make a nice cover over the amprack, and everything will appear flush into the back.
Thanks for looking!!!!!
Is that a f-body?
DC.jpgDC POWER
sweet build man... I bet you met his needs with this build........ whats this thing tuned to?
cubic ft, and subs being used?
my neighbor across the street has the same body Talon, I will show him this build, and see if he wants to do something like this
I kept saying fiberglass, but looks good with wood too
