trying to tune a wall with 2 18's messed with torres (cant import screen) so 36" tall 43" wide 20" deep..trying to tune between 30-33hz...i get the cut out of the box, i cant figure out the dimensions of the port...slot port 34.5 x 4.75. 30" length but the calc shows physical length of 23.75" i dont get it....re calc shows it completley diff....and i know you guys swear by torres so i just want to only have to do this once...sub displacement =.50 and im using 1 extra baffle...
thanks in advance....woofers are pap wmd2k's 18" x2 dual 2's
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
port is gonna be behind driver side, top to bottom, i can go longways if you think it will be better...i have the room to go either way...
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
So okay, you're using 3/4 MDF or birch correct? With that variable out of the way, here we go:
You have one MONSTER of an L-port. The piece of wood making up the one side of the port(as the other is the side of the box) would be 13.75 deep by your height of 34.5".
The other piece that makes your L would be 7.6"(roughly 7 5/8 of an inch) and the same height of 34.5". That type of port gets you tuned to about 33(just under). I also added for .20 in bracing displacements.
thanks a bunch!!!! i have a subs up/ports back tuned @ 40hz =148.5 on termlab @ the dash...( my ports are choking) and no lo-lows either...so i think flippin in to a wall should be the wisest and loudest option. you guys agree?
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
thanks sierra!!! and yes will be using birch, thanks for the cut sheet.......
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
For a port 30" long and 4.75" wide box 20" deep double baffle I get:
L Port Internal Assembly Parts:
Front to Back = 13 x 34 1/2
Extension = 10 x 34 1/2
  • Who's Online   0 Members, 0 Anonymous, 603 Guests (See full list)
