i definitely go by bigger is better. when i have all the equipment i want, ima do a run of 0 ga to each amp. your old power wire was 8ga? my speaker wire is 8ga :) glad you upgraded tho
yep im glad to, cant wait to fiddle with my amp now that i have the new wiring, im unsure off the speaker wire i have running from my amp to subs...hmmm.... makes me curious.....doesnt say on the wire, might just have to go buy a roll of 8GA speaker wire, very handy :P
1 12 inch infinity 1240watts...only can fit that in a hilux single cab...
1 infinity 1000 watt mono block...
2 Hifonics Zues 6.5" Components
2 Hifonics Zues Tweeters
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
Another question:
does my brown/black earth cable have to be the same gauge as my red power cable which is 4gauge
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
yes,i would not go smaller.
will the system still work with the 4GA power cable and 8GA earth?
if it will work will it fuck anything up?
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
It will still work and it MAY not cause any damage but it's a good practice to get in the habit of making good quality earths. Worst case scenario you can get some seriously bad voltage drop causing your amp to blow.
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
chances of that happeinin? percent outta 100?
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
Depends on a lot of things but I never like to gamble especially with something as expensive as car audio. When using $3000+ amps you don't skimp on anything at all. Just do it right the first time and you'll never run into problems later :)
My Youtube Videos
can i use some of the leftover 4GA red power cable or does it have to be the black/brown coloured wire
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
Can be any colour you like as long as it's equal or larger size than your power cable, my earths are blue :). Also make the earth as short as possible. How long is it?
My Youtube Videos
i believe if you have a small ground wire like your 8ga, then upgrading the power wire to 4ga will do you no good. you can only be as strong as your weakest link, and your weakest link would be your 8ga ground wire. mine is purple :P so color doesnt matter. but size does
  • Who's Online   0 Members, 0 Anonymous, 827 Guests (See full list)
