Can be any colour you like as long as it's equal or larger size than your power cable, my earths are blue :). Also make the earth as short as possible. How long is it?
i have about 30cm left, i dont know how many that inches that is for you yanks.
anyway if i change the earth that running from the amp to the body of the car, do i need to change the one thats running from my battery to my car body?
1 12 inch infinity 1240watts...only can fit that in a hilux single cab...
1 infinity 1000 watt mono block...
2 Hifonics Zues 6.5" Components
2 Hifonics Zues Tweeters
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
hahahahahaha that made me laugh.
as for upgrading the wire by the battery...you COULD. when getting a new alternator it's suggest(or required) to do the 'big 3' upgrade. which means increasing the wire gauge going from your alternator to your battery, the ground from the engine to the chassis of the car, and the ground from the battery to the car body. so yeah you're definitely on the right track. it's not necessarily required now at the moment...but if you got enough wire, it definitely wont hurt. then if you do decide to do the big 3, that's one less wire you gotta worry about :)
EDIT: i just underlined that section to show the part that you were referring to in your post. not tryin to confuse...
Edited by ExpoSport
Yes upgrading the battery earth cable is also crucial. As mentioned earlier your circuit is on as strong as its weakest link. And infact the circuit does not just include your amp's wires but also the wires coming off the battery. No matter how great your massive amp power cables are and if you have perfect earths up back, if you have a single crappy 8awg factory earth coming off the battery it will be the weakest link in your system rendering all those upgrades near useless . I had five 0awg earths coming off my front battery when I upgraded.
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
yeah i only have 1 atm because i'm just trying to get my system setup the way i want it. THEN when i know it's how i want to keep it, i am going to go back and overkill on everything as much as i can
ok that helped me heeps :P, thnx heeps, just to be annoying i have another question will i get more NOTICIBLE power if i get some 12 or 8GA speaker cable from my subs to amp or just leave what i have now, dont bother askin me wat i have now i have no clue but i know its not 8GA
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
How much power, in RMS are you running per amp, and how many runs of speaker cable come from each amp. Could you get a picture of the cable you are using?
My Youtube Videos
estimating by what you have in your sig...as long as it's not TEENY TINY you should be ok with it for 400 watts. think i used 10ga on my friends speakers rated at 200/250 watts RMS
sorry i meant to say the speaker cable running from Amp to SUBWOOFER, i have the speakers running of my head deck
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
yes...i still stand by my statement :) i have 3k going through my 8ga wire, so you're still probably in the safe ballpark. oh and by speakers i meant the woofers. my bad
i have the 1 amp which is (im typing this directly off the manual) :
1x 456W RMS channel at 4 OHMS and <1% THD+N
signal-to-noise ratio: 70DBA (reference 1W into 4ohms)
1x 657W RMS channel at 2 ohms, 14.4V supply and <1% THD+N
dynamic power: 761W at 2 ohms
theres more but to much to type anything more u need i will tell u
ill get a pic of my cable running of my amp now :P
EDIT: here are some pics
http://i266.photobucket.com/albums/ii270/c.../Picture017.jpg
http://i266.photobucket.com/albums/ii270/c.../Picture013.jpg
that red 1 is 4GA so it shows u in comparison so u might know wat the speaker cable is
sorry bout how blury it is no room in boot or trunk to get farther pic
Edited by chesthertZ
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
  • Who's Online   0 Members, 0 Anonymous, 1085 Guests (See full list)
