Hey guys i new to this, im not sure how to add a second battery to the car.
Can someone help me clear up my confusion.
-Alpine CDA-102
-Rockford Fosgate T1652
-Rockford Fosgate P1652
-Audioque 2200
-Fi Btl N2 12
-KCA Karma 0 Gauge Power
-KCA Karma 0 Gauge Ground-Sound deadened trunk and doors
Posted (edited)
Put the battery wherever your gonna put it, the run a 1/0 wire from + on front battery to + on secondary battery and then either run another 1/0 wire for the negative or just ground it to the chassis.
On the positive wire, fuse each end of the wire as close to the battery's as possible.
Edit- Ninja'd :Doh: lol
Edited by sprkn_ranger
Oh i see not as hard as i Thought,Only thing i dont understand is when you say Fuse Both Ends?
-Alpine CDA-102
-Audioque 2200
-Fi Btl N2 12
Like this:
Batt----fuse-------------------fuse----batt
And get the fuses as close to the battery's as possible so you have the least amount of unprotected wire as possible to short out on something and catch on fire. And make sure you fuse to the wire's rating. So if your wire is rated at 300A use a fuse no larger than 300A.
Alright Awesome thanks for your help, im still learning.
-Alpine CDA-102
-Audioque 2200
-Fi Btl N2 12
im still learning.
this is a great place to do it
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
