ok now this is what you should do next, have the brain out and find out which wires control the actuator and check the voltage on it when you click the button for it to pop, if it is getting volts then you know the actuator is going out if its not getting volts then you know there is a problem with something else.
whats wrong with fat chicks? they are like mopeds, as long as your friends dont see you riding it, they are a blast! hahah
I am dumb as a stump. I live in the south and we are all dumb here.
I agree, and was also my plan. Check voltage to the actuator first.
Yep thats the best way to troubleshoot the voltage then c from there. Ay op did you do anything or get it fixed?
I
Im getting ready to check voltage. Everything seems to be working fine just that issue
when you say button then remote..how is button wired through its own relay? does brain have built in relay packs? when fully closed is takes more effort to pull the latch,meaning more amperage through solenoid.. its definetly electrical orientated,, check grounds.. most solenoids the housing is ground.. make sure the mounting points are paint free.. plus lube latch mechanism up so it move easier..that will help pop also
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 420 Guests (See full list)
