Kenne Bell 2010 Mustang GT: Speed (slow) and Sound Build
do you think your arc was the problem with the DD amp? Arc'd and you had OL which blew the amp
I think the blown amp caused the arc. Otherwise I would have had issues with the saz3000 as well.
that makes sense bc they were just as close before. Hmm must have been something in the amp
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
ok Ken, here is what I came up with:
Has a radius of 2 45/64" which comes out to 2.70" X 2 and you get a diameter of 5.4" Not sure where you can find a pipe or something with an inside diameter of 5.4
Might find something with 5.5" inside diameter. Then you will also have to trim down the ends of the wood in the corner of the port to accomodate for the thickness of the pipe.
