252chevyboyz Posted June 6, 2012 Author Report Share Posted June 6, 2012 @kika: As long as it does rated and doesn't completly starve the elctrical ill be ok. Ill be running all 1/0 wire which will done by the end of the month and ill have the shuriken batts plus new H/O alt by this coming November/September hopefully. - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
KiKaZz74 Posted June 6, 2012 Report Share Posted June 6, 2012 Alright.sounds good. Everyone said I would need a battery but my stock alt and bat are working just fine right now. Granted I don't have a led voltmeter and just use the one in cluster but I still don't see any drop with 1700w My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 6, 2012 Author Report Share Posted June 6, 2012 Ill be replacing the front batt first with probably shuriken bt100 or bt120 and if I come into some extra cash I may go with XS but they hurt the budget pretty bad. Great batts though. A H/O alt is something I know ill need to have it running full tilt on a termlab at idle and keep the voltage at or around 13.6 Also I'm still up for amp suggestions and reviews. Feel free to chime in -James - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 12, 2012 Author Report Share Posted June 12, 2012 What are yall's thoughts on the MB Quart ONX 1.2000D? I should have my budget of right near 300 dollars this week or by middle of next week. Just need to go ahead decide what I am ordering. Also willing to look at any offers on used amps that do a good 2k rms. -James - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 13, 2012 Author Report Share Posted June 13, 2012 Anyone have any opinions on the MB Quart ONX1.2000D? It says 2000w RMS but does anyone know if it does rated power? Also is it a clean 2000w? I'm taking a guess at this but does Maxxsonics test amps at 13.6v or 14.4v? Any help is appreciated and thank you -James **edit** Also that is at the top of my budget and so is the Hifonics brz2100.1D. Any good clean 2k rms amps between $250-$280? Can ya'll recommend a reputable seller for a Soundstream RUB1.2500D? I found this seller and wondering if it is a safe and reliable seller. http://www.savinglots.com/lotprod.asp?item=RUB1.2500D - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 13, 2012 Author Report Share Posted June 13, 2012 If anyone has any Crescendo bc2000d's or anything similar for sale please post up -James - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 13, 2012 Author Report Share Posted June 13, 2012 So in other words I'd be better off going with a Hifonics brz1700.1d? I have the Autotek SM2-1200 which is a 1200w a/b class amp. The brz1700.1d would be an upgrade from this? or should I go with this over the hifonics? because I'm guessing they are both rated at 14.4v http://www.savinglot...item=RUB1.2500D **edit** What do ya'll think about these 2 sellers? http://www.amazon.com/Hifonics-Brutus-BRZ1700-1D-D-Class-Block/dp/B0036B8URU http://www.buy.com/pr/product.aspx?sku=217088693&sellerid=34734045 - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 13, 2012 Author Report Share Posted June 13, 2012 Opions anyone? I got the funds in my hand today -James - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 13, 2012 Author Report Share Posted June 13, 2012 Which Amp Shall I choose? http://www.buy.com/pr/product.aspx?sku=217088693&sellerid=34734045 http://www.amazon.com/Hifonics-Brutus-BRZ1700-1D-D-Class-Block/dp/B0036B8URU http://www.savinglots.com/lotprod.asp?item=RUB1.2500D Does anyone have a Soundstream rub1.2500d or Crscendo BC2000d for sale? - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
252chevyboyz Posted June 13, 2012 Author Report Share Posted June 13, 2012 Or the Soundstream Tarantula series amps? http://www.savinglots.com/lotprod.asp?item=TX1.2000D - 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene My Selling Feedback Build Log Link to comment Share on other sites More sharing options...
