mids can take a whole lot more power that an tweet can and its a lot harder to hear tweets distort then mids
user error would be my guess i have blown up many of tweets in my day
just saying
What did the specs say on the component set for maximum power ??
Did the specs say (Even with the passive corssover) what the minimum frequency response was for the tweeters ??
The maximum power for the components is 90 watts RMS, my amplifier puts out 90 watts RMS @ 2 ohms/channel ( Infinity Kappa's are 2 ohms ), The Tweeter's frequency response is 3500 - 35000Hz
http://www.sonicelectronix.com/item_13970_Infinity-Kappa-10.9T.html - Tweeters
http://www.sonicelectronix.com/item_13971_Infinity-Kappa-680.9cs.html?SearchClickout%5Bquery_id%5D=10158821&SearchClickout%5BIgnore%5D=1
Component Set that came with tweeters
http://www.sonicelectronix.com/item_31877_Kicker-ZX350.4-11ZX350.4.html - amp
Edited by ShockStruck
ive noticed on my kenwood, the door speakers start to distort once i turn the sub level to 15, mine is set to -5
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Did you have the amp bridged running to one set of mids, or just hooked up normal?
The amp is wired normal, left positive and negative to crossover input, right positive and negative to right crossover input. My amplifier has 2 separate gain controls, crossovers, and bass boosts labeled amp 1 and amp 2. The components are wired to amp 1. The amp puts out 90 watts RMS/channel @ 2 ohms, the speakers maximum power handling is 90 watts RMS @ 2 ohms (These are 2 ohm speakers).
http://www.sonicelectronix.com/item_31877_Kicker-ZX350.4-11ZX350.4.html - My amplifier
get some crescendo tweeters. im powering mine with a kicker 850.4 and are still going after months of screaming. i did set my crossover to 125hz and im using a crossover from crescendo for the tweeters. my brother keeps having trouble with his infinity kappa tweeters. it was even sending his amp to protect mode
From experience I know that the tweeters are very sensitive once you over power them or give them any little distortion they blow. When I install the kappa components I always put the tweeter at -3 . The midrange is solid but the tweets are crap.
tweeters may have not enough power after powering your components
What does this mean?
Ignore that.
2002 Ford Explorer XLT
Front Stage: Crescendo CCX 6.5's
Rear Stage: ???
Two 15" Powerbass M154
Audiopipe AP15001d
Pioneer DEH-P5100UB
