1 amp, 5 blown woofers?
Johnny248
well maybe you are sending too much powaaaa
or your box is terrible! what kind of box, did you build a new box for each sub!?
Two different vehicles. 10's and 12's in different enclosures lol
-= J-dUb =-
....no 12 step program can cure my car audio addiction...
have you thought about maybe the dd1 WAS working properly and the amp is just bad in general if the distortion light was on always?
you can easily test this by hooking the dd1 up to the back of your headunit and testing for clipping there, just to make sure that the light doesn't always stay on. and if you hook it up to the amp after and it just stays on, the amp is junk.
I was using it on a different vehicle this past weekend, and in the middle of that, the DD-1 distortion light was on. I've tested it with 4 different head units, and 5 different amps. It is def a DD-1 problem.
-= J-dUb =-
damn dude dont know what to tell yah then! maybe get a different amp lol
probably could have gotten a new amp instead of buying 5 woofers lol
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
i gotcha man. once you get the replacement, definitely test it on the headunit first to see if its a good replacement, then test it on the amp.
edit: nevermind ninja'd like a mother.....
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
lol x2. i would honestly get rid of that p.o.s
Johnny, youn have one or more of four problems-
1. person operating the system is driving a clipped signal to the amp = sub gets burned
2. amp is crap and is being driven past it's ability to reproduce the clean signal it is getting=output is clipped=sub gets burnt
3. voltage and/or current at the amp is below operating parameters= Clipping=sub gets burnt
4. enclosure is grossly inadequate - person is driving the system beyond it's operating parameters= sub gets burnt
edit-
5. ambient temperature is WAY too high=normal operation of the amp/sub combo simply pushes the sub past the thermal tolerances
*** had this happen in a system with everything in the trunk, even witrh fans it smoked a weak sub***
1. person operating the system is driving a clipped signal to the amp= sub gets burned
I will check voltage drop and ground resistance at the amplifier. I'm about to toss this thing.
I should have just bought another amp several woofers ago, but with shelves full of speakers I just do the quick easy thing and stick something else in there lol.
-= J-dUb =-
