box help again, sorry guys
I got a good post for a box build for my Fi Q 12, but I just found out its external dimensions wont fit. The sub displacement is .16 cu ft and should be getting from 800watts RMS to 1200 watts RMS. My MAX dimensions are 10 depth x 20 height or width x 30 height or width (as long as the depth is 10 inches im golden because its going behind the seat of a Ford Xcab.) preferred tuning frequency on Fi's site is 28-33 Hz in a box from 1.8 cu ft NET- 2.5 cu ft. but if you have a preference for it, i'm open to suggestions. your help is verryy much appreciated...its just been such a long day and I don't feel like fooling around with Torres and sketchup since I'm not that good at it yet. So I'm hoping someone kind could figure this one out? thanks so much, your help is much appreciated.
It could be like this:
Enclosure Specifications:
Fb = 33 Hz
Vb = 2 ft^3
External Height = 23.5 in
External Width = 30 in
External Depth = 10 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 30 x 23 1/2
Left & Right Sides =
Side 1 = 22 x 7 3/4
Side 2 = 22 3/4 x 7 3/4
Top = 25 1/4 x 7 3/4
Bottom = 30 x 7 3/4
L Port Internal Assembly Parts:
Top to Bottom = 18 x 7 3/4
Extension = 8 1/2 x 7 3/4
  • Who's Online   1 Member, 0 Anonymous, 1332 Guests (See full list)
