b-dubs89 Posted June 7, 2012 Report Posted June 7, 2012 i bought a 0 gauge rockford amp kit and it come with a 300 amp fuse in the fuse holder , i am going to be running stock bat and alt and i am wondering if that fuse may be too big , worried about not being protected against dc short , the amp i will be useing for subs is tma 1000/1 and i will have a smaller amp for mids and highs . i know my wiring is overkill for now , i am just wanting to make sure a 300 amp fuse isn't too big for my vehicle to be protected
varietyguy Posted June 7, 2012 Report Posted June 7, 2012 The fuse rating is meant to protect the wire from shorting and catching fire. You can put a smaller fuse on it if you want but there is no need to 1992 Mazda 323 http://www.stevemead...323-wall-build/
diatribe Posted June 7, 2012 Report Posted June 7, 2012 Yep, the 300 amp fuse is for the wire. You need another fuse by your amp set to its current draw. Probably around an 80 amp will do. Check your manual to see what the manufacturer recommends.
sprkn_ranger Posted June 7, 2012 Report Posted June 7, 2012 The amp should have its own on board fuses to protect its circuits. The fuse on the wire is for protecting the wire from heating up and catching fire should it ever short out. S just use the 300A fuse that it came with and your done. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
yUmadBro Posted June 8, 2012 Report Posted June 8, 2012 I think the 300 will be fine, better to have more than less
Emmet Posted June 8, 2012 Report Posted June 8, 2012 I think the 300 will be fine, better to have more than less Bad mentality when working with fuses.... Not all that good when the fuse doesnt pop and the wire melts or catches fire. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
