Go-N-Def Posted June 8, 2012 Report Posted June 8, 2012 About port size. i keep hearing it need to be bigger. why? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
RAM_Designs Posted June 8, 2012 Report Posted June 8, 2012 With too small of a port you can get some port noise, which basically just sound like a chuffing kind of sound. Also, a larger port is going to give you some more output as well. There's such a thing as too much port, so it's more of a "staying in the middle" sort of thing. Just by looking at your avatar, you can definitely add some more port area and not see any bad effects from it. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
bkolfo4 Posted June 9, 2012 Report Posted June 9, 2012 A small port also does not work correctly at high volumes. When the air velocity becomes too high, the port is no longer tuned to the correct frequency, and if it is bad enough, the box will begin to act like a leaky sealed box instead of a ported box. It is REALLY hard to get a port too big. Most car box ports are right on the edge of being large enough, that is why people have better luck with larger ports. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
bassface Posted June 9, 2012 Report Posted June 9, 2012 A smaller port lowers tuning, a larger port raises tuning. A longer port lowers tuning, a shorter port raises tuning.
Nate Futuristic Posted June 9, 2012 Report Posted June 9, 2012 I'm kinda scared about my box tuned @ 28-29hz I hope it sounds good lol (4 15s on 5k) down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
Noobtastic14 Posted June 9, 2012 Report Posted June 9, 2012 A smaller port lowers tuning, a larger port raises tuning. A longer port lowers tuning, a shorter port raises tuning. This advice without context is almost useless. There are several variables, Including the port area, port depth, and box size. With everything held constant, you can adjust one and it will change tuning. To "fine tune" your box you want to single out just one and adjust it. -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
