Would the big 3 raised my voltage that much?
doing the big 3 isnt intended to gain voltage...proper charge batts techinically help raise voltage (less work for the alt) caps take in energy while they try to charge, which is a big strain on ur alt. the big 3 is to help increase the amount of amperage to go from ur alt to ur battery, some people get some voltage gain at idle, but not every vehicle will get the same results.
Feedback Thread: http://www.stevemeadedesigns.com/board/topic/152368-littlebuck1919s-feedback/#entry2177586
i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
6/18/82 - 4/17/12
R.I.P. to my sister Shana
I would dump the cap and just run batteries
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
go ahead and charge up both batts, its not a permanent solution but i dnt see how it'd hurt to keep em topped off, otherwise id suggest if u have a smaller amp laying around to just use that for now...idk, less to worry about for voltage issues if u run a smaller amp
6/18/82 - 4/17/12
