why is my jeep doing this???????
doesnt start doing the hesitations till 30 seconds into the video please help
changed every damn sensor. and still deos it. changed ecm and still does it. only does it when i first start it, i have to drive the car and floor it to make it stop. when i floor it it backfires and hesitates like it wants to stall out..... please help
I can't hear it to well, is someone giving it gas from inside the car? or is that is just semi-stalling on itself?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
could be MAF or MAP depending on which one you have, clogged fuel filter or bad injectors, fuel pump could be going out, bad coil, plugs or plug wires, alot of possibilities
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
no one is giving it gas its doing it all on its own. but it doesnt actually start till 30 seconds into the video
Check the fuel pressure or maybe its some fouled plugs. 4.0 right
yes its a 4.0 fuel pressure is normal and just changed the plugs. has new o2 sensors and throwing o2 sensor codes i dont understand
new map sensor. if the fuel filter was clogged or an injector was bad wouldnt it do that through the whole powerband
How many miles are on the wires?
Do you have an OBD-2 reader to pull codes, if the SES light is on?
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
couldnt a clogged cat create this problem? im no mechanic
When my cat was clogged on my Caddy it was just a loss of power first at the higher speeds then became a loss of power during initial take off from stop, it also was the cause of my P101 - MAF sensor code which was strange as fuck lol. No stalling though, not saying it couldn't happen but yeah
2015 Mazda 6
