Suburban Update 24 DC Audio 12s Coming Soon!
Alt bracket installed
Dora is straight up nasty.
10+ vids coming
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
When I get home ill upload one :)
Sub Amp: 3 DC 9k's
pics of bracket installed and who makes it
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
probably two on each side ray. what side are your alts on driver or pass?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i have 2 on drivers and 1 in stock location.. if you did 2 on pass 2 on drivers they dont make a belt long enough.. i have 3rd to longest they make.. on my setup now
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
good point.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What you end up having to do is run a wider belts with more ribs made for vehicles like semis and other such type vehicles, and you have to cut 2-3 ribs off the belt.
I believe Steve also does this too with the heavy duty Gates belt (the green belts).
