Relyks Posted June 10, 2012 Report Share Posted June 10, 2012 (edited) okay im really just puzzled at this point when i turn my truck off i have so much more gas then when i turn it back on the next time. its like someone takes my gas when i park but its does not happen. i know a lot of things are factors of gas mileage so i will state below things i have done to my 22re PCV Valve , Harmonic Balance , Belts , Fuel Filter , Fuel Pump , Fuel Tank , Plugs Wires , Cap , Oil change , Air Filter , Battery , Thermostat , Master Cylinder/Brakes , 17" rims , low profile tires , a piece to the gear shifter , Radiator Cap , Gas Cap , Sending Unit. sea foamed the engine and honestly i got better gas mileage when it was running rough then now i feel like the timing is off a little but if it is its a little under not over so it idles pretty low also i had a problem with the fan clutch so i bypassed the clutch and it runs constantly now. I Have pictures of all parts and and engine and can take more if needed ill be checking this post a lot. ps. i also drive pretty low idle so im not just burning it like crazy Edited June 10, 2012 by LT.Smoke Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
fox_racin4 Posted June 10, 2012 Report Share Posted June 10, 2012 If your fans always on theres one issue, also, just because your not reving high while driving, doesnt mean your getting good mpg Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
LT.Smoke Posted June 10, 2012 Report Share Posted June 10, 2012 If your fans are always running then there may be a burnt out relay or fan speed control switch that is going batty... I had to replace relays in my Impala for the fans not running properly between that and the combo of my thermostat going bad Quote Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌 Link to comment Share on other sites More sharing options...
EricM9104 Posted June 10, 2012 Report Share Posted June 10, 2012 i had a problem with the fan clutch so i bypassed the clutch and it runs constantly now. There's your issue... Without the fan clutch your fan is creating a much higher drag on your motor. Quote 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
Miguels Posted June 10, 2012 Report Share Posted June 10, 2012 If your fans always on theres one issue, also, just because your not reving high while driving, doesnt mean your getting good mpg If your fans are always running then there may be a burnt out relay or fan speed control switch that is going batty... I had to replace relays in my Impala for the fans not running properly between that and the combo of my thermostat going bad if you read right he has a clutch fan and just removed the clutch. i think he has a mechanical fan which they do rob HP and hurts gas mileage Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Miguels Posted June 10, 2012 Report Share Posted June 10, 2012 i had a problem with the fan clutch so i bypassed the clutch and it runs constantly now. There's your issue... Without the fan clutch your fan is creating a much higher drag on your motor. ninja >.< Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
fox_racin4 Posted June 10, 2012 Report Share Posted June 10, 2012 Yup...thats what i ment... Quote 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole Link to comment Share on other sites More sharing options...
Colin - STAPUFT Posted June 10, 2012 Report Share Posted June 10, 2012 You said it is like someone is stealing your gas.... Does your vehicle have a vented fuel tank / system? Or call for a vented gas cap? If the gas cap isn't vented, then check to see if it is vented somewhere else. If you have a vent that is stopped up with grime, mud, bugs, etc... it could be pressurizing and pushing fuel out instead of venting off like it is supposed to. I've seen this madness happen. Nearly drove me crazy looking for it once. Quote 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back. Link to comment Share on other sites More sharing options...
Relyks Posted June 12, 2012 Author Report Share Posted June 12, 2012 (edited) i got a vented gas tank and a vented gas cap both are brand new. i thought so with the fan clutch as well but problem happened way after the fan clutch ( fix for the fan ) edit also just to clarify some things 91 22re are not very technical engines everything is pretty much mechanical ( sept for fuel injection and basic electrical and the computer that adjust the idle from 0 to -6 degrees. Edited June 12, 2012 by Relyks Quote --> My Toyota Build Link / AudioQue Build . <-- Latest Update 1/16/12 Link to comment Share on other sites More sharing options...
b-dubs89 Posted June 19, 2012 Report Share Posted June 19, 2012 locking gas cap . checking vent is a good idea too . gas gauges are not that accurate always . i had something like this happening with my malibu , and in addition to all i would have it not want to take gas when i would go to put gas in , almost like the anti siphon was jammed . started not filling it up seemed to make a difference for the better . still somewhat puzzled as to what may have been happening . staypuffed has a good theory about building presser and forcing gas out somewhere . if you think some one is stealing your gas , get a gamecamera . Quote Link to comment Share on other sites More sharing options...
