2nd Design for IVX 15
yUmadBro
i'm looking for some help on an enclosure build for a single skar ivx 15". it will be going in the trunk of a 2001 honda accord. i'd like the enclosure ported with the port facing the cabin of the car because i will either be folding the backseats down or opening the backseat hole to the cabin. i want to kind of stay compact if possible so i can keep the wiring clean under a false floor and also keep my amplifiers separated. anyways i have some pictures of the trunk and then another i edited in paint with the dimensions of inside. if theres anyone that can give some good input i'd appreciate it. anyway heres the specs for the subwoofer. thanks
Ported @ 35 HZ: 3.5 ft^3
Displacement: 0.15 ft^3
Depth: 6.25"
Outside Diameter: 15.125"
Cutout: 13.875"
Heres some pics and measurements sorry their not that good and hard to visualize :sorry:
Measurements of trunk
Trunk opening: 39 1/2 "
Backseat to end of trunk: 40"
Floor from brake light to brake light: 46"
Heres the height measurements sorry
The inner trunk to floor is 21"
The side of the trunk to floor is 19"
The trunk bars are both 18"
thanks again
You could try this:
Enclosure Specifications:
Fb = 35 Hz
Vb = 3.5 ft^3
External Height = 18 in
External Width = 37 in
External Depth = 15 in
Port Width = 3 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 37 x 18
Left & Right Sides = 13 1/2 x 16 1/2
Top & Bottom = 37 x 13 1/2
L Port Internal Assembly Parts:
Front to Back = 10 1/2 x 16 1/2
Extension = 9 x 16 1/2
Generic dimensions assembly guide:
If you have any questions let me know.
go to skars website. find you sub. and in scroll all the way down and go click on the manual. . . its a pdf file and in there is a box design for that sub. found it today for my vvx 15
  • Who's Online   0 Members, 0 Anonymous, 908 Guests (See full list)
