which yellow top should i be using?
why XS > yellowtop?
no yellowtops in there
why XS > yellowtop specifically??
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Those special yellow tops that say "XS Power" on the side.
This. XS Power is the best! Kinetik is decent too and a little more affordable. You could also check out the Deka intimidator series. I'll get you some links
There are also several name brands you may be surprised to find out are actually Deka Intimidators, just rebranded. :peepwall:
Actually I wouldn't be the slightest bit surprised if someone told me kinetik, stinger, juice box, shruriken, ect were rebranded intimidators ;)
Op I'm working on those links if you want them
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
i guess im askng why no one uses yellowtops??
and if you do post the links, i have NO idea what to look for in a good battery.
tips and advice would help
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
People do use them. Usually when they have a hook up and can get them cheap as hell. There good batteries, I used one before for my first couple systems and there great BUT there are better batteries out there that are more suited to our car audio needs.
Edit for grammar
Edited by mikeg321
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
How many systems have you installed? The reason I ask is because 2500 watts is a lot for someone starting out. It's a lot of pull on a stock alternator, regardless of battery. What amp do you plan on doing this with?
ok thank you ^_^
that kind of stuff makes much more sense to me and i appreciate that :)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
140amp alternator is my stock alt
i will also be doing the big 3 upgrade with 1/0awg
running a 5,500 power acoustik BAMF series amp (hopefully soon to be upgrading to a Crescnedo 3k)
7" plaine-jane touchscreen
7band paragraphic EQ
knukonceptz Krystal RCA's
going to be purchasing a 15" XL in a week or two
not as new as i think you think i am xP
no this does not mean im closed minded to learning new things :P
Edited by Robby Holmes
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
Your going to want to get the largest you can fit in the stock location and the largest you can afford to go in the trunk.
Best http://m.summitracing.com/search/brand/xs-power-batteries/?toggleResults=display
Good
http://www.dekabatteries.com/assets/base/1740Intimidatordeepcycle.pdf (<- PDF)
I tried to get you some more links but I'm at work and it just got busy
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
I'll be nice this time and tell you guys what I've seen as far as rebranded batts
Superstart AGM (Deka intimidator)
NGT Xtreme
diehard gold AGM
Duralast platinum AGM
Diehard platinum AGM (rebadged odyssey)
I can't be sure on all of them as I have not tested all, but I have a diehard gold AGM group 47 in front with a kinetic 2400 in back with a stock 160A alt and 2 runs of 1/0 and I do ok. Drop to 14.2 usually at idle from 14.6v.
  • Who's Online   1 Member, 0 Anonymous, 1489 Guests (See full list)
