The port does have to bend, like n8 said you need the Width of the port away from the back wall.
If my calculations are right, first wall should be 21"
Then 90 degree turn, second peice is 3.5"
Gives you 24.5" physical port length, and 30" of actual port length
Have to acct for the width in the turn to the actual port length
Hope this helps/makes since
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Doesn't work, because a center port should be cut in half after the bend.
SMD Super Seller
My Feedback Thread
My mistake, I thought you meant a side port with three common walls
  • Who's Online   0 Members, 0 Anonymous, 1128 Guests (See full list)
