Its possible to run 14v or 16v batteries but it's pricey and easy to screw something up. You can also make you alt put out more voltage - even a stock alt.
Unless you know what you are doing, take the advice that's been given and stick with 12v batts.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
16v batteries need to be charged at 18.4-19.2v (2.3-2.4v per cell)
You will blow out your stock electronics if you try and feed them that much power. Plus you would need to find an amp that can candle that sort of voltage
  • Who's Online   0 Members, 0 Anonymous, 943 Guests (See full list)
