Yesterday while driving I had the AC on and out of no where white fog started coming out of the vents. It didn't have a smell and it dissipated almost instantly. It was really hot and humid some I'm hoping its just some water vapor. If I turn the AC off but still have it blowing the fog stops coming out. Any idea what it is exactly? Is it harmful to breathe in?
Also when the AC is on there is a loud noise, sounds like a vacuum. (this sound is nothing new) Maybe a hose fell off or something.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Sounds like the cOmpressor was run without oil. In which case it's trash. Doesn't explain the fog. Unless the condenser blew up internally, in which case the white fog would be the refrigerant. I wouldn't recommend breathing that in, but I'd I remember right smoking cigarettes is worse.
This page is crispy_chick3n approved.
© crispy_chick3n inc
line pressures realy arnt good for much except telling someone weather or not they have refrigerant or not. thats the shitty part about ac systems, there realy is no way to truely diagnose a major failure, aside from physically examining the entire system, which takes hella time, and costs a ton on the labor side of things. however if you are good at diagnosing ac systems, there is a lot of money to be made as a tech. if it were me i would just forget about the ac and roll with windows down. that white fog was more than likely the refrigerant, and the only way for that to get into the plennum to get out the vents is through the condensor, which means the dash more than likely has to come out, then if it damaged the ductwork beyond repair there is no telling how high the cost can go. ive seen people pay up to $2k to have their ac systems reworked, and the fuckers still leaked.
LMFAO and anyone that knows a/c at all knows exactly why i am laughing...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
** digging for old ac books to see how wrong i was**
Diag this one then.
Front and rear A/c vehicle with Expansion valves. High side pressure stays static with the compressor engaged but the low side sucks its way down to zero and the front a/c wont cool. Turn on the rear a/c at the same time and all of the sudden the low side pressure comes up into the 30 psi range with high side pressures at 150-200 and is blowing cold but the front a/c is still blowing ambient temperature.
You cant diag issues like this without reading the pressures. Same thing with the reid valves in a compressor with the low side needle bouncing in a 20-30 psi swing but it still cools just not very well. There is alot you can figure out from reading gauge pressure.
Edited by kandiman71874
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
Read all you want. Its real life experience that teaches you things to look for. Most books wont cover a lot of the tricks you pick up working in the field. Gee, sounds like a lot of other hands on jobs..
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
  • Who's Online   0 Members, 0 Anonymous, 1210 Guests (See full list)
