How long should you let a new windsheild set and cure before you hammer on the subs again?
I made the mistake of waiting a day after and I have to go back to safe lite to get it fixed. The windshield apparently slid down, and the weather stripping is almost exposing where it sits. Thanks!
New build coming soon..
depends on what kind of urethane they use....I work for one of there competitors in the new england states, our glue states that the car is safe to drive after one hour (meaning the urethane has reached its tensile strength, and if a collision occurs, the glass will hold even with the passenger side airbag going off against it). But the glue does stay wet (not fully cured) for a couple days after its been applied. If safelite's glue is similar, you could wait a couple days to make sure. The glass sliding down can definitely happen regardless whether you had your subs going or not, especially on a hot and humid day.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I had 3 windshields put in my truck and i waited a full week before i started playing my sub and closing the doors like normal. For that first week after its installed i had it sit in the sun but it was during the middle of winter so i wanted the bead to get warm and adhere well. I also would close my doors very slowly and usually bump them with my hip to close the latch all the way because if you shut them like normal it will build up pressure in the cabin and that can pop the seal on the window. Even though there are vents in the cabin it still builds up pressure from slamming the doors and stuff.
A week should be more than enough time for you especially if its warm out. Also one little side note is be careful of putting your mirror back on and slamming on it with your bass. I went through 2 windows alone due to the adhesive the mirror button was held on with being so poor it broke off and every time i had it reglued it would take a chunk of glass with it.
They may when they install it at the glass shop. The glass shop near me had my truck for a hour and a half before i could go pick it up every time i had it installed. If you follow the glass down past the plastic trim where my defroster vents sit and the wiper arms are there are little rubber slats that the glass sits on however the stock glass is the only thing that touches the very bottom of that stopper, the aftermarket glass i had put in (different brands,stock one was a pilkington, first one was not stamped to show the name, second one was a pilkington) was not as long as the OEM glass so it sits about 1/2 of a inch up from the ledge built into my panel. Everything else fits just fine and i have had no problems with it leaking or anything.
Yeah im not worried about it though. Lifetime warranty on the glass and labor from the shop that put it in and my insurance covers glass 100% so im set. lol. You will be fine though just go easy shutting the doors and dont slam on the sub for a week and it will set just fine. I did mine all in the winter we just had and it was 20 degrees outside and it worked just fine.
that slamming doors thing is actually a myth. A lot of shops don't use stops so the shield won't slide, (there are very few that need it) they just tape it up for 24 hours (our glue is 5 minutes, then that things not going anywhere). Some cars/trucks come with stops but most of the time they get hacked off by the tech who replaces the shield. Theres a lot more corruption in this job than one may think....
