is the 15 l7 4 or 2 ohm..............................
The random noises my friend's makes would be enough to make me want to take it out and smash it with a sledgehammer. I think it'd get more hits than the review you were thinking of ;)
The 1500 can push two perfectly the l7 15 does not need much to get it loud.
The box will be much more important in this case just build it on the larger side of the specs if you are a little worried.
Kickers need a LOT of box volume as it is anyways.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
I say try it and if you blow it up ... buy a new one at walmart
in September
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
You will blow a single L7 off almost 2k watts that T1500 will put out at charging levels. My rule of thumb with Kicker is RMS capability minus 10%
I like that thought.
JVC AVX-44 and 360.2
Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port
Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2
Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
  • Who's Online   0 Members, 0 Anonymous, 728 Guests (See full list)
