MTTornquist's Corolla SQ Build *now with Linear Power 11/26
Here what I got done the last couple of days.
got the holes for the sub drilled and installed the t-nuts.
Also got the front baffle mounted for good
You will have to wait to see what the little ribs on the sides will be used for, that is the only thing the clamps are holding
Also got the trim panel cut to fit the trunk
Picked up all the hardware that I will use to mount the sub and trip panels on
Didn't expect it to be nearly this expensive, cost me $30; but its all stainless.
And picked up one of these from menards, should come in handy soon! :good:
thanks for looking in, that's all for today.
Leave a comment! :)
Looking great. Another question... How does the aero port stay in place and not move around?
2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/
Kenwood 352U HU
(2) Incriminator Audio Death Row 12''
Soundstream Tarantula 1300W
MTX 6.5'' mids &
Infinity 4x6's in front doors
Building as money comes in... beauty panels and amp rack
1996 Jeep Grand Cherokee Traded for a 2004 Malibu
2wd-4wd conversion
4in. lift
32'' Tires
2 Alpine 6.5 in front
2 Sony 6.5 craploads in rear
Build: http://www.stevemead...__fromsearch__1
1999 Suzuki Sv650(Work in Progress)
There is liquid nails all over the back side that touches the back of the wall. Then the hole in the baffle is crazy tight around the pipe where it comes out, that hole is also lined with liquid nails. Hahaha it isn't going anywhere! :good:
You will see how I finishup the end of the pipe tomorrow, Ive got a good idea and it should look great!!
I think I've got a big update for you guys today! :good:
To start with I got the beauty panel all mounted up nice, same matching stainless hex bolts to hold her on!
Then i had to cut the holes in it to match the baffle.
Starting with two 3/4 inch holes with a padle bit.
My new flush trim bit worked great for this!
Sub cutout:
Then got the port cutout:
holy sawdust:
Here is the pile where i flipped the box over:
After I got everything cleaned up, took up couple beauty shot for you guys!
Nice 'ol roundover:
Show me some more love guys!!
Leave a comment, got more coming tomorrow! :good:
that box looks really nice.
one question though is how smooth of a transistion is it from the straight pipe to the elbows?
I'm not really sure how to answer that man, I think its pretty good, there is obviously an edge but I think its pretty clean.
I defiantly don't think it will cause much turbulence in the port though
Thanks for the kind words! :good:
i havent really looked at the previous pages but it looks good man. real clean. i was actually thinking about doing teenuts on my center console when i get around to it lol
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
I would say go for it! they're super easy to use and work great, I am very happy that I decided to use them :good:
Looking really good.
Kenwood 352U HU
MTX 6.5'' mids &
2wd-4wd conversion
4in. lift
32'' Tires
Sorry its been a couple days since the last update, been really busy lately!
Meanwhile I ran my first half-marathon on Friday!! :good:
Anyways, first i had to do the wiring.
You know I'm using all stainless steel hardware :D
Holes drilled:
And installed:
Inside:
And did some some sharpie artwork in case the paint on the ends of the bolts ever wears off.
After that the top was ready to go on!
I didn't have very many clamps that could reach far enough...... so i threw on a couple weights!
This top is on perfect!!!
After the glue was died I took a couple more shots:
So whats next is I need to paint the beauty panel and make the mounts on the back of the box for the amp and the will be in and playing!
Thanks for looking!
Leave a comment with your thoughts!
