First box. No clue what to do
I have decided that i am going to build a box for my 2 RF Punch HX2 10's.
Is anyone here able to give me a design with all the cut measurements? I know its a lot to ask, but when i am filling out information in sub enclosure calculators, i have no idea if my port is too long or too short and whether i have enough cubic feet. My available space is H-11.5 W-36 D-20 in the trunk of a Toyota Camry.
Equipment: (2) RF punch hx2 10"
(1) Hifonics BRZ1200
I want a box tuned around 30-32hz. I listen to a lot of rap and a lot of decaf.
What do i need to glue and seal the box together?
Thaks!
Hey I just wrote a tutorial in the last 2 days that is for questions exactly like this.
If you check it out you should be able to get a starting idea.
Thanks!
Here is the link:
http://www.stevemeadedesigns.com/board/topic/145174-ported-box-design-a-tutorial/
If torres isn't working use this. It isn't as fancy, but it gets the job done. Just remember, port volume does not count towards box volume.
http://www.the12volt.com/caraudio/boxcalcs.asp#porsq
Remember to input all displacement correctly. Use 3/4 mdf or a comparable material. Try stuff out, it doesn't cost much at all.
2015 Subaru Outback. That is all, I refuse to touch it.
Here is a suggestion very much like the above:
Enclosure Specifications:
Fb = 32.048 Hz
Vb = 2.125 ft^3
External Height = 11.5 in
External Width = 35 in
External Depth = 17 in
Port Width = 3 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 35 x 11 1/2
Left & Right Sides = 15 1/2 x 10
Top & Bottom = 35 x 15 1/2
L Port Internal Assembly Parts:
Front to Back = 12 1/2 x 10
Extension = 14 x 10
Assembly guide (generic dimensions):
Let me know any questions.
  • Who's Online   1 Member, 0 Anonymous, 800 Guests (See full list)
