Box For 2 12"
Can any of you help give me plans or just tell me how to build a custom box for 2 12" Infinitys, this is the description of the sub box, i greatly appreciate it, right now i just made a sealed, box , dont know the cubic inches or anything like that all i know is its a sealed box that holds 2 12" subs lol thanks in advance, (really wanna get it louder):
Diameter: 12" (300mm)
Sensitivity @ 2.83V/1m: 93DB
Power Handling (RMS): 300W
Power Peak (peak): 1200W
Frequency Response: 23Hz- 400Hz
Impedance: 4 ohms
Voice coil diameter: 2" (51mm)
Mounting Depth: 129mm
Overall Diameter: 316mm
Cut-out Diameter: 284mm
Sealed box volume: Vbox=125ft cubed or that lil 3 above 1.25Ft (35.40 liters)
1 12 inch infinity 1240watts...only can fit that in a hilux single cab...
1 infinity 1000 watt mono block...
2 Hifonics Zues 6.5" Components
2 Hifonics Zues Tweeters
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
whats the displacement of the subs? you just gotta play with some numbers....get some rough external dimensions...then subtract 1.5" from all of them (assuming ur using .75"wood)....multiply h x w x d...then take that number and divide it by 1728...that will give you your internal volume....just make sure sure you have the added volume to take into account sub displacement...
i likes me some audio stuff...
loool, heeps confusing, oh well, yeah like u said ill just get a couple of hundred $$$ worth of mdf and just make a couple of different designs :P whichever 1 works the best i keep, and the rest go on ebay :P
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
its really not that hard...say each sub displaces .1 cubic foot for example...
your external dimensions are 15"h 25"w 20"deep...
subtract 1.5" from everything for internal dimensions....13.5"h 23.5"w 18.5"d
multiply: 13.5*23.5*18.5 = 5869.125
divide: 5869.125/1728 = about 3.4cubes
subtract sub displacement: 3.4-.2 = 3.2cubes net
lol im extremely new 2 car audio, so i dont have a clue wat u jsut said and im aussie so i dont have a tape measure with inches :P, sorry bro
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
Do you use the Metric S.I unit system?
if that means i use Millimeters and centimeters and metres then yes i do use that, lol
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
i want this box to be for pure SPL
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
ok, then what are the maximum dimensions that you want to take up in your vehicle, length width and height, for the box.
i want a ported box
Edited by chesthertZ
2 cross-over boxes
1 run of 4GA
200 Fuse
1 Kenwood Head-deck
  • Who's Online   1 Member, 0 Anonymous, 1303 Guests (See full list)
