Jordan Guess Posted June 18, 2012 Report Posted June 18, 2012 Usually every day, I try to learn a new bit of information on SMD. What I am struggling with today is dealing with (box rise/ ohm rise)...whatever you guys call it? as well as getting my net volume to match with port area per foot, and tuning frequency. I am about to receive two DC M1 lvl 4 12s with lvl 5 soft parts. The specs I received is that they will run nicely on 1500 rms each but the impedance of the subs are different than what I am used to (being 1 ohm, 2 ohm, 4 ohm)...these actually are providing a 1.4 ohm resistance per coil...so what do I do as far as an amp goes? get something 3000 RMS at 1 ohm?....or two separate amps?. I was told that they like 15-17 cu in port area per foot and like about 1.5 cu ft per sub....that is if I provide sufficient power to them...but what if I don't? ( say 1000 watts per sub)...how do I figure out the box rise? I will probably end up making the box to its preferred specs but I am just struggling entirely with torres. MY max dimensions are 20H x 39 W x 15D and am hoping to just make it double chambered instead of separating them. woofer displacement is .21 per sub and I am not sure what # of common walls i should use (does this mean how many edges of the box will I use for the port?) I really hate to ask people to design me boxes without compensation, but Ive struggled beyond the point of my knowledge and could use a hand. thanks.
Robby Holmes Posted June 18, 2012 Report Posted June 18, 2012 nevermind my bad '08 Chevy Cobalt coupe 2.2 base model trunk build: 2 9512iSC flatwound alum 1.5 coils -extra 9500 spider pack -8" platinum carbon dustcaps 1 DD Z1 (.375ohm nominally daily) 3g31 AGM 320a Ohio Gen alt 1 DD S4 4 channel 4 VO-M8v1's (holes cut for 3rd pair) 2 CS 6.5's 2 VO-B1's Sony XAV-601BT all Knu Krystal RCA's Cadence 7band EQ ______________________ 148.3db @ 32hz (burp) 148.4 @ 37 & 38hz (burp) 146.xdb 90sec average (center windshield)
Mr.JaunDurfle Posted June 18, 2012 Report Posted June 18, 2012 If you click on the help button in the Torres calculator and then scroll down towards the bottom of the pop-up, there are links that will show you what "# of common port walls" means. 2001 VW Passat Sportwagen Alpine ICS-X7HD DC Audio 5K SSA 15" XCON Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS Incriminator Audio IA6.4 XS batteries, KnuKonceptz wirez, Second Skin
Jordan Guess Posted June 18, 2012 Author Report Posted June 18, 2012 alright thanks, but what about my wiring options with 1.4 ohms per sub? Should I go with two amps that are two ohm stable, or one amp thats 1 ohm stable?
Joe X Posted June 20, 2012 Report Posted June 20, 2012 Dual 1.4 ohm coils in series subs in parallel gives 1.4 ohm final load.
