alenv10 Posted June 20, 2012 Report Share Posted June 20, 2012 needing a amp for 4 obsidian audio d4's i have 2 d4's right now at a 1 ohm load on a hifonics hfi1500 but i want 2 more and will have a problem with amp this way.. i cant wire 4 d4's to a 1 ohm load NOTHING DOWN HERE YET OBSIDIAN FTW Link to comment Share on other sites More sharing options...
andrew018018 Posted June 20, 2012 Report Share Posted June 20, 2012 hifonics colossus.. 3200 watts a 2 ohm My System (in VW golf/Rabbit mk2) (1) Hifonics Brutus 2010D @ 1ohm (1) Hifonics Zeus 440 Mids'nhighs (3) JBL W10Gti subs (2) JBL GTO838 (2) JBL GTO936 (1) run of 3/0 Gauge ofc (1) Ac Delco120ah 850cca battery (front) (1) Ac Delco 45ah 330cca battery (rear) (1)Sony Gt630ui hu 34hz tuning Link to comment Share on other sites More sharing options...
Cardboardcat15 Posted June 20, 2012 Report Share Posted June 20, 2012 http://www.sonicelectronix.com/item_6712_Kicker-ZX2500.1.html My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/ Link to comment Share on other sites More sharing options...
Miguels Posted June 20, 2012 Report Share Posted June 20, 2012 http://www.sonicelectronix.com/item_26141_Rockford-Fosgate-T2500-1bdCP-2010-Model.html my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
alenv10 Posted June 20, 2012 Author Report Share Posted June 20, 2012 okay maybe i should have made it clear that i am not in the budget of $1000 amps lol NOTHING DOWN HERE YET OBSIDIAN FTW Link to comment Share on other sites More sharing options...
RooTxBeeR Posted June 20, 2012 Report Share Posted June 20, 2012 Just to throw it out there, try checking out strappable amps to. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
alenv10 Posted June 20, 2012 Author Report Share Posted June 20, 2012 name some strappable amps, how do u strap amps? NOTHING DOWN HERE YET OBSIDIAN FTW Link to comment Share on other sites More sharing options...
RooTxBeeR Posted June 20, 2012 Report Share Posted June 20, 2012 I can't think of any lower powered ones at the moment, but almost all Rockford Power amps are strapable. To strap an amp, they for one need to be able to do that. When you get amps that can do it, they will tell you how to make those strap, the reason why I suggested it, is most amps can't be strapped at 1 ohm, normally 2 ohms. Which is exactly what you are looking for as a final ohm load. You could possible just pick up another of the exact same amp that you currently have and just gain match the amps to make sure they are identical in output. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Miguels Posted June 20, 2012 Report Share Posted June 20, 2012 you wont find any that does 2400 at 2 ohms. if you are getting 2 amps might as well just run them at 1 ohm http://www.ebay.com/itm/Hifonics-Brutus-BRZ2400-1D-2400-Watt-RMS-Class-D-Mono-Car-Amplifier-Power-Amp-/300695090798?pt=Car_Amplifiers&hash=item4602d2f66e&vxp=mtr#ht_4344wt_1139 my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Miguels Posted June 20, 2012 Report Share Posted June 20, 2012 I can't think of any lower powered ones at the moment, but almost all Rockford Power amps are strapable. To strap an amp, they for one need to be able to do that. When you get amps that can do it, they will tell you how to make those strap, the reason why I suggested it, is most amps can't be strapped at 1 ohm, normally 2 ohms. Which is exactly what you are looking for as a final ohm load. You could possible just pick up another of the exact same amp that you currently have and just gain match the amps to make sure they are identical in output. if he gets 2 amps might as well just run 2 subs at 1ohm on each amp my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
