honda civic coolant blowing out overflow
So my car got a little warm on temp got home and seen some coolant was coming out thr overflow. So i replaced the thermostat and gasket and flushed it.
Seemed everything was running good but today car was sitting still and a/c on today at work and car started getting hot opened hood and there was a little fluid by the overflow and the overflow was at the top.
So wondering what it could be ive heard the rad cap or hose collapsing or worst thing headgasket any.help please and thanks
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
see if you can have your radiator cap tested to make sure it holds the correct pressure
What year Civic, how many miles? Sounds like it could also be a clogged radiator as well.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
my old civic work car did this also ( 94 eg hatch)
1st issue was a old radiator hose collapsing ( old hoses are real soft) and a little bit of airlock in the system will virtually stop all flow
then i replaced all the hoses and a week later the head gasket went.. bc it was alreeadt stressed..because it got hot a couple time
Also check the hose that leads into the heater core. That one stopped my buddy dead in his tracks on his EG as well.
Sorry forgot to post year and milage.
1998 civic ex
165k
1.6liter
Guess i can replace cap and hose since wont cost to much and hope thst helps fix it.
have you actiually bled the system??
release that little bleeder valve on the inlet of the radiator hose housing.. fill it up till it runs out... run it for awhile let it cool and repeat process..
also radiator cap was 15bux for mine ( same cap same radiator as you.. also radiator cost me 85bux)
No i didnt bleed it i could not find the bleeder valve.
checked the hoses they all seems good and not collapsing. Got a new rad cap, Let the car cool down for like 3 hours and when i opened the cap pressure shout fluid out the overflow and there was alot of air pressure from under the cap. any ideas. Im leaning more to the head at this point
