honda civic coolant blowing out overflow
first bleed the system.
any white smoke, check your oil also, if your oil is the color of chocolate milk or if you have a ton of white smoke then its a head gasket.
What do you mean by "a little warm"? Do you have a gauge or an idiot light in your dash? How long was the temp "warm" ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I dont have a bleed valve looked around said if i had one it would be on the top hose near the motor.
no white smoke no milky oil
warm as in from the Cold to Hot temp gauge it was like 3/4 to Hot.
only like 2 min if that.
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
Run it with the cap off until the thermostat opens. To make sure the coolant is flowing. Get the cap back on quickly though, before the fluid heats enough to come out.
what he said , have some coolant to add as you do this when you do this air should find its way out , keep adding till you cant . might be a good idea to run the heater while you are doing this too
might want to try and look in the neck of your rad with a flash light to see if you have any scale
do your fans come on?
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Looking in rad seems clean fan does come on outside now letting.motor.warm.up with cap off and lettibg air out
make sure there isn't a plastic bag or debris blocking the front of the radiator.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
