tlh_360 Posted June 30, 2012 Author Report Posted June 30, 2012 Ya I was thinking about that but ppl said it wasn't necessary. I'll through one in just to be safe. This box is 2.53 cubes with 48sq" of port area, 18.99sq" of port area per foot tuned to 34.40hz. I'm eventually going to through 2k on it and was told that 2.5 cubes with 19sq" port/ft at about 33-34hz would be good for 2k. Quote
Decaf Posted June 30, 2012 Report Posted June 30, 2012 I think the box is too small, 50sqin is fine, but 2.5cuft is too small volume dictates response, and since this sounds like daily being tuned to 34hz I would increase volume to increase efficiency and keep the box from being as peaky if you didnt pay attention, I have 3500w amp powering mine, in 1cuft bigger box, LOL Quote
tlh_360 Posted June 30, 2012 Author Report Posted June 30, 2012 Yes it is for daily. Ya I must have looked over the 3500w. OK back to the drawing board......lol. On another note how does it take that 3500watts? Quote
tlh_360 Posted June 30, 2012 Author Report Posted June 30, 2012 (edited) Edit:ignore Edited June 30, 2012 by tlh_360 Quote
Joe X Posted June 30, 2012 Report Posted June 30, 2012 So you did have the space for a bigger box. Quote
tlh_360 Posted June 30, 2012 Author Report Posted June 30, 2012 (edited) Ya the max dimensions are 18 tall x 32 wide and the depth max is 17.5 and that's right where my floor folds up for my tire well(where the amps/batteries are). I said 18x32x16 in my OP but 17-17.5" can be done but like I said it's at the max. You'll need to double up the front so tick baffle in Torres You'll need bracing as well so that will be around 0.02-0.03cuft (3/4 or 1" round bar) Put a 45's in the the port and opposed side to port(not needed on front as double baffled but you can still put) Other that port is all good at 16-17sq" per ft port And power that with 15-1800rms and you'll be fine, if you want 2k+ drop the net to 2.5net 19sq" per ft port This is why I was at 2.5 cubes. But if 3 cubes will be better then I will definitely do that. Edited June 30, 2012 by tlh_360 Quote
412 CVX Posted June 30, 2012 Report Posted June 30, 2012 oh dear... why did it take so long to catch that mistake. i'd give the sub at least 3.5 cubes. shrink the port down to 15-16 per cube so you can get more volume. i hate to see such a nice sub go in a shitty box. PM me if you have any further questions or need further assistance. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
tlh_360 Posted June 30, 2012 Author Report Posted June 30, 2012 How are one of these Option 1: 2.93 cubes 49.50sq" port area 16.89sq" port area per foot 34.01hz Option 2: 3.08 cubes 49.50sq" port area 16.06sq" port area per foot 33.17hz Quote
Joe X Posted June 30, 2012 Report Posted June 30, 2012 You have 3 cubes do 3 cubes no issues with the amps you listed, both of the above boxes will do so build the one you like best. Quote
412 CVX Posted June 30, 2012 Report Posted June 30, 2012 are you kidding?? the zv.3 will take 2k no sweat. 3 and a quarter net, MAYBE. you're choking it at 3 cubes. that's for sure. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
