can someone sketch up and give me a cutsheet for an enclosure..........2 sa8v.2
36 length
14 tall
11 bottom
5top
will have a 4 inch aero at 17 inches long firing toward passenger side...............i would appreciate any help......
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
You can get it directly from Torres, I noticed that the resulting net vol is way to high for that sub. Would likely make a nice box for two subs.
its for 2 subs....... and my computer doesnt like torres for some reason......ive downloaded it a million times and just doesnt work
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
for torres you have to download it then when you download it ull see that its a uexe file delete the u then save or open it whichever i cant remember which one. Then it will work i couldnt figure out for awhile how to get it to work
whats wrong with fat chicks? they are like mopeds, as long as your friends dont see you riding it, they are a blast! hahah
I am dumb as a stump. I live in the south and we are all dumb here.
This is the output from Torres:
TOP 36'' x 5''
BOTTOM 36'' x 11''
SIDES 12.5''H x 5''D1 x 11''D2
FRONT/BACK 34.5'' x 12.5''
ANGLED SIDE 34.5'' x 15.23''
1.27 cubes @36.5Hz
TOP 36'' x 5''
BOTTOM 36'' x 11''
1.27 cubes @36.5Hz
appreciate that bro.............and i thought i was closer to 2 cubes with sub displacement and with port.....hmmm?
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
gonna be bout the most box you can get back there man..without losing some leg room.. id built it and try it out see if you like it.. dont pretty it up just see if it sounds good to ya...could prolly build 2 boxes outta 1 sheet
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
0.6-0.7 cubes per sub is about right for those subs, Your tuning is a bit high, maybe add an inch or two to the port IMO.(to get to 35Hz).
Edited by Joe X
that length will allow his port to load better off the side wall.... its more important in this truck than lowering the tuning 1 hz.. the truck itself likes to play low i can play into the upper 20's and im tuned at 37 in mine
power: dd m4
yeah im not gonna pretty it up at all......and you are the one who gave me the dimensions and how to fire the box......so when its done i will let you know......only question i have the front baffle will be at a 45dg cut on top and bottom correct........................
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
