Does anyone have any experience with upgrading the big 3 on a 2001 or similar S10 Blazer 4.3l? I dont know what wire is the positive on my alternator and looked underneth and I did not see any bolts on engine block. If anyone has done one please help me out.
the positive wire on the alt is the only big wire coming out of a bolt sticking out the side of the alt casing.
The big bolt @ 3 o'clock
Edited by LilTeddyP
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
The only wires should be the big red one (factory big is about 8ga) and the plug in for the voltage regulator. Do you have more than that?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
ok I found the red wire. Now where should I ground the negatve on my battery too? I dont see a place I would feel comfortable grounding it too. Also anyone find a spot on the engine block to place a ring terminal?
I found some random nut on my engine block when I had my Explorer that I used to ground, you just have to take your time and search around.
About the fuse, if you are going to put one on there just put it closer to the battery, somewhere like 4" from the battery will be fine.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
I used the factory grounding spot, just follow the factory grounds off the battery.
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
  • Who's Online   0 Members, 0 Anonymous, 488 Guests (See full list)
