box rise and ohm load help?
Alright so I just picked up an Audison LRx 4.300 and have a quick question about bridging it.
It is rated for 220 rms @ 4 ohms bridged and isn't stable below 4 ohms when bridged. I would like to run it in 3 channel mode with my front end off the first 2 channels and my sub off the bridged channel. The sub I am looking at is an AA assassin. The problem is that the assassin only comes in a d4 coil configuration. So I am wondering if I wire the sub down to 2 ohms then expect to see at least 1.5 ohm box rise this brings my final ohm load to 3.5-4 ohms that the amp actually sees. Does this make sense and will it work without risking the amp?
Thanks!
Matt
No, you cannot use that logic.
At one time, AA had the assassin in a single 4 ohm coil. PM me your zip and I can see if any are available and get you a price.
Current system:
Previous systems:
PMed
Can you explain to me why this doesn't make sense?
You cannot rely on impedance rise. it can happen because of a number of factors, but it's not something you can really calculate and predict. you can't rely on impedance rise to save your amp. if for some reason you don't have the rise you thought you would, you could potentially blow your amp. plus, there is no rise when the sub is at rest, so your amp will probably go into protect because of the lower ohm load.
overall just not something to be relied on.
More box builds
I'm with captain stupid.
why not just run it un-bridged?
i didn't think of that... that might work too
More box builds
  • Who's Online   1 Member, 0 Anonymous, 1662 Guests (See full list)
