running it unbridged will yield less wattz
no it doesnt. 100w per channel (for two total channels). you'd get 200w bridged. same exact thing.
if you run each coil to each channel, there is a chance (and it will probably happen) that one coil will get slightly more power than the other one because bass isnt always 50/50 on both channels.
edit: yeah you're right my bad. but that amp is expensive so i'd recommend against running it under the lowest rated impedance.
Edited by Kranny
I understand that but the amp does 65x4 @ 4 ohms or 210x2 @ 4 ohms bridged. So if I have a d4 sub and don't bridge the amp then the sub is only getting 130 watts but if I get a single 4 ohm sub and bridge the amp then it would get 210 watts. Similarlly if I get a d2 sub then I can leave it unbridged or bridge it and it will get 210 watts.
Is there a different sub you guys would recommend for sq that is good off around 200-250 watts and is availible in s4 or d2 coil configs? That is if I can't get my hands on a s4 assassin.
Thanks
4ohm bridged should be the same as 2ohm stereo. just like you said, a d2 sub will get the same bridged or stereo.
Exactly so I need either a d2 sub or a s4 coil to get the full 210 watts.
Been talking to Bkolfo4 and he said the assassin line has been discontinued but they are going to look around and see if they have the parts to throw together an assassin 10 in a s4 coil config. *fingers crossed*
  • Who's Online   0 Members, 0 Anonymous, 9332 Guests (See full list)
