Sound deadening on a budget?
Deadner rips and punchers easy in my truck I did 100% coverage over all screw holes and clips was still very easy to just push the clips threw made my door panel fit tight as hell to
But the best place to put it is on the inner skin of the door not inbetween the door panel and door frame
OK wait.. behind where the windows sits when it's down or behind the frame the door panel connects to? I'm planning on doing EVERYTHING around where my midrange drivers will sit behind them and all for sure and then between the panel and frame it connects to.
I'm gonna hate
How do y'all feel about these things http://www.sonicelectronix.com/item_22347_The-Install-Bay-VXT65.html just for moisture protection? Will they make my comps sound worse since they will seal them off but be flexible? I will still be deadening the doors road noise bleeds through them like mad, the stock tar-mat in the doors sucks.
I'm gonna hate
Behind the window the skin of the door
OK, got it.
im pretty sure water can go through foam...
I think that depends on the foam in question, these look like they're made of pretty dense stuff. But I don't know, hence the asking.
I'm gonna hate
if the seal around the window and at the bottom of the window is good you dont have to worry about water. if you seal is bad you can get new ones.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
This stuff seems too good to be true. twice as thick, and way cheaper then others? how is this done? $50 for 4 doors, It seems like an awesome deal, but I was always told if it seems to good to be true, it probably is...
1996 Ford Explorer Eddie Bauer V8 AWD
So far with the Ford/JBL Stock Stereo system, Alpine System coming soon.
Or it's new to the market :P even the best companies have that "look at me! you've never heard of me, but I'm cheap and great!" moment until they get more popular and can move products on their name alone regardless of price. Like Kicker.
I'm gonna hate
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
