White Lightning Posted July 3, 2012 Report Posted July 3, 2012 Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
bassface Posted July 3, 2012 Report Posted July 3, 2012 Thats an ingenious way of mounting them together like that cableguy, props.
White Lightning Posted July 4, 2012 Report Posted July 4, 2012 I forgot to mention that those are the 8" Iso-Kits in the Trailblazer ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Audiojunkie23 Posted July 4, 2012 Author Report Posted July 4, 2012 Very interesting. Is that a bandpass enclosure? Sorry if that's a stupid question.
White Lightning Posted July 4, 2012 Report Posted July 4, 2012 Just ported and tuned to 24 htz ... External port tuning Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
Audiojunkie23 Posted July 5, 2012 Author Report Posted July 5, 2012 Is there a benefit to external ports? Or will iso's work in a normal ported enclosure?
blkgp_03 Posted July 5, 2012 Report Posted July 5, 2012 Hello all, Just wondering on what would be a good woofer to run in an Isobaric setup? The set up where one woofer is mounted directly behind the other. (Don't know the actuall terms) I was thinking the Sundown E-8v.2 or the D.A.D AMH10's? Just wondering if it would be bad to use woofers that have big motor structures or large mounting depths? P.S. I don't have the pockets for Blues Audio equipment. Thanks! Blues Audio merged into Linear Power. If I were you I would buy those 2 BL8 that are on ebay. They are the older ones but they are just as good as the new ones. Way to steal my recommendation. Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch. TaylorFade, on 02 Jul 2013 - 9:38 PM, said: Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box. Tell him T-Fade sent you.
White Lightning Posted July 5, 2012 Report Posted July 5, 2012 Is there a benefit to external ports? Or will iso's work in a normal ported enclosure? yes to both questions ... Hello all, Just wondering on what would be a good woofer to run in an Isobaric setup? The set up where one woofer is mounted directly behind the other. (Don't know the actuall terms) I was thinking the Sundown E-8v.2 or the D.A.D AMH10's? Just wondering if it would be bad to use woofers that have big motor structures or large mounting depths? P.S. I don't have the pockets for Blues Audio equipment. Thanks! Blues Audio merged into Linear Power. If I were you I would buy those 2 BL8 that are on ebay. They are the older ones but they are just as good as the new ones. Way to steal my recommendation. LOL ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
White Lightning Posted July 5, 2012 Report Posted July 5, 2012 Is there a benefit to external ports? Or will iso's work in a normal ported enclosure? Trick enclosures just got a whole lot easier! It used to be if you wanted to do something wild you invested long hours to build the perfect exotic enclosure. That has all changed now! The Blues™ Iso-Kit™ is a pre-assembled isobaric driver structure utilizing two Blues™ Loudspeakers wired together to create one 4 ohm driver system. The units are assembled using a transparent acrylic tube which allows the internal structure to be revealed, while providing a strong and minimally small sealed chamber between the two drivers. Electrical hook up of the unit is accomplished by attaching speaker wiring to the standard connectors on the rear driver. You can even reverse mount the assembly outside the enclosure, showing off the whole see thru structure and making the internal box even smaller since there is no internal box displacement subtracted for the assembly. The Iso-Kit™ can be used in a sealed or ported enclosure with a single unit per chamber. No removable service panels are needed to access the internal driver since the pre-assembled unit drops in a standard sub enclosure through a normally sized speaker cut out. This also eliminates air leaks in the enclosure from removable panels. The Iso-Kit™ is available in an 8 inch version and a 10 inch version. The 8 inch Iso-Kit™ 8 uses a standard 10 inch cut out opening to mount into, and the 10 inch Iso-Kit™ 10 uses a 12 inch mounting cut out. The mounting flange has a hole pattern that matches a regular loudspeaker mounting pattern, making the Iso-Kit™ easy to retrofit into an existing speaker enclosure. When used in an existing enclosure the lower limits of the frequency response will be extended, the Iso-Kit™ will have a much lower distortion level than the single driver it replaces, and the bass response will be smoothed. An enclosure built specifically for the Iso-Kit™ utilizes as little as half the internal volume (net volume) normally required for a single woofer in a traditional enclosure. For example, when building an enclosure specifically for the Iso-Kit 10™, an enclosure of .75 cu. ft., or half the average sized enclosure for a single Blues™ BL10 , will have the same basic response level as one single 10 inch driver in a 1.50 cu. ft. enclosure. Smaller enclosures than this can be utilized with satisfactory performance. The Iso-Kit™ will have a much improved bass response over the driver it replaces. The Iso-Kit™ will also have increased electrical power handling due to the dual motor structures shared by the two drivers, rather than one motor assembly on a single driver. The Iso-Kit ‘s™ output could have a slightly lower efficiency level than that of the driver it replaces, however, this is a normal condition in all isobaric enclosures. Porting the enclosure to make use of the sound from the rear driver will increase the output level and overcome any losses in efficiency. Frequency tuning of the port into the frequency range from the lower 30 to mid to high 20 cycle range will insure proper power handling and low bass extension. Tom Nousaine, of Car Stereo Review, originally tested the first generation of these units in 1992. His response after testing was, “Spatially, The twin Iso-Kits were excellent - No, make that superb.” We have changed a lot since then and made things better. The new generation of Blues™ Iso-Kits™, have a higher efficiency and a lower Fs than the old generation, making them a better sounding system than ever before! Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
