SlamminBeats' Saab 93 *2 DD 9512i's, 2 DD M2b's, XS Power, KnuKonceptz, SS* New TL Numbers Soon
i would look into switching head units. maybe just pick up a cheapie to test with and keep on a shelf somewhere for worst case scenarios. somethign isnt right. I know people dick ride Knu but Ive never really been a fan of any of it at all. Same thign with pioneer heads. which pioneer is it? Do you havet he SLA and all that stuff off etc? you could be missing something tiny. I know on my head unit LOUD is on by default.
true. i double check it a million times and catch little things, then turn them off and get the same results.
/\ How wide is your port, and how much space is there between where your port ends and the back wall of your box
I am asking this because if your port is 5 inches wide, then the port wall goes back so far, and lets say there is only 4 1/2 inches between where the port ends and the wall, this could be whats causing the problem.
I've seen it happen before in error box builds and cause problems like your having, thats why i am asking, where the port area starting inside the box is smaller than the actual port area itself
its built right if your asking
5.25 and i believe 5.25
Wait, so if port is 4.25" wide and the back of the port and wall isn't the same length (2.5"), Is there always going to be issues? Or is there a certain time that having that distance smaller than the port width ok?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
i cant comprehend any of this port length shit right now because im soo burnt out on life (aka spring break)
but i know when i built it that it was right. the port opening in the back or w/e needs to be bigger or equal to the port...did i say that right?
i used torres..no bends so it has to be right...besides this box has yet to play these subs at all....so this all happened on my old box
oh ok,
and Dublin,
as slammin said, the port area where the pressure exits HAS to be the same port area at the entrance to the port inside the box, otherwise all sorts of messed up shit happens, that of coarse unless your doing some sort of folded horn design, which has to be perfectly designed to be successful.
Where slammin stated as greater, he is referring to, if the port was only 6 inches deep, because thats all you needed for tuning, then there would be a larger distance between the back wall, and the end of the port wall.
I was basically making sure the entrance to the port was the same area as the exit.
so if your port area for example, was 12x5 then you would want to be sure that where your port begins inside your box is a 12x5 opening,
I have seen a box that had a 12x5 port for example, and inside the box the port wall went back so far that it measured 12x3, see what I mean?
Its kinda confusing to explain with out sitting and showing you on a piece of paper or an actual box lol
i have updates for this build. we blew up one of the 9512s, ill have videos up in a second. the triple joints on both subs blew.
not on the newly reconed one but from the previous mess up. so slammin 30 sec averaged a 145.1 with a broken sub!!!
vids of carnage will be up in a bit. luckily i had a recone on hand so we will get it in today or tomorrow!! maybe he will get loud this time.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
here are ze videos
the surge protector fuse blew. in this attempt
this is where we just hooked up one coil to the wall to see how long it would last.
BMW M340 xDrive
I've never had ground loop issue on my pioneer deck. What model do you have?
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
2 different ones ive been playing with...sigh
deh500ub and idk the other, ill look later
i have a ground loop on my pioneer deck.. and i dont clip the deck at all.. up to volume 62.
and the the fuckkk are you destroying so many subs? your not putting all that much power to them.. unless your playing like 20hz full tilt bottoming the sub out with only 30 sec on a fresh recone... you should have an issue...
theres something going on that you have to be missing.....
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
he was playing trunk bang by dorrough on full tilt... thats how he blew the trip joints ahah
BMW M340 xDrive
