Alphasonik PMA2500 Guts Class A/B
Here goest some guts.
Any info or experience on this amplifier will be appreciated. Swapped it out with my audiopipe 1500d to test at a 4 ohm mono bridged on two kicker cvx 15's and it hits great.
  • 500 Watts x 2 @ 4 ohms Stereo
  • 800 Watts x 2 @ 2 ohms Stereo
  • 1500 Watts x 1 @ 4 ohms Mono
  • Dimensions: (W x H x L) 8 1/4" x 2 5/8" x 21 1/4"
  • Hour Meter
  • Remote Mount Digital Voltmeter(included)
  • Heavy Duty One-piece Extruded Aluminum Heat Sink
  • Beveled Clear Acrylic Protective Cover
  • Tiffany-Style Input and Output RCA Jacks
  • Parallel Line-out RCA Jacks
  • MOSFET High Speed Switching Power Supply
  • Milspec Double-Sided Glass Epoxy Circuit Board with Through-hole Plating
  • Heavy 4 oz. Pure Copper PC Traces at All Preamp and Amplification Stages
  • Solid Brass Nickel-plated Terminal Blocks (4-gauge Power, 8-gauge Speaker)
  • THD: 0.05
  • Signal-to-Noise Ratio: >100dB
  • Frequency Response: 5Hz~50kHz
  • Input Impedance:10K ohms
  • Input Sensitivity: 200mV~8V
  • 4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
  • Thermal Cooling Fan
Edited by teamace24
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Yup thats an hour meter and what it reads sounds crazy.
It reads 51xxx hours which is quite a bit of years.
Its a class a/b i think and im not sure when it was made but it was more than 6 years ago lol.
I think it might be over 9 years old after googling a bit.
Edited by teamace24
Just can't beat class A/B technology ...
X2. This thing was built solid in its day. Even by today's standards I'd say it's built very well. I think somebody should get a clamp test done and see what she really pushes :)
Its a high voltage amp, not a high current amp ... Clamp test would not be that impressive ... But somewhere around 40 amp current draw if I had to guess ... But VERY musical ...
  • Who's Online   2 Members, 0 Anonymous, 1944 Guests (See full list)
