It is a 1 ohm load 100%. Think of it like this. If you have one subwoofer lets say a dual 2 ohm coil setup. When you wire it in parallel like you did it will be at 1/2 the impedance of ONE coil reading (going from 2 ohms for one coil to a 1 ohm reading with both coils) Now if you wire it in series you will double the resistance and go from 2 ohms per coil to 4 ohms with both coils.
Think of it like this: For a single sub you will take 1/2 the original impedance you have for ONE individual coil when you wire it in parallel. You will double that original impedance for ONE individual coil when you wire the sub in series.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Well the terminals on the mono amp act as just one terminal. So both the positives are on the same lead, it's just for wiring convenience.
Ranger is right. The + and - leads are connected in the amp as one terminal. If you are still confused just use one set of terminals and wire the subs up as normal.
