boostin302 Posted July 6, 2012 Report Share Posted July 6, 2012 hey guys. ive been trying to figure out the tuning of this port. here is a pic of the port with the measurments drawn on it all measurmants are inside minus the top of it which is outside measurements. ( the 7 1/2 part) the MDF is 3/4. the box measurements are 27" depth, 34" wide, 15" height. those are outside measurements also. MDF is 3/4 thick of course. i tried to figure it out on torres but got confused on the baffle part on the calc. the woofer total displacment is .40 ( 2 12's, .20 each) there is pics of the box build on my build log if you need anymore pics on it. thanks josh edit: here is link to build log with the box build pics. http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/page__fromsearch__1 My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines. Link to comment Share on other sites More sharing options...
boostin302 Posted July 7, 2012 Author Report Share Posted July 7, 2012 anybody know? My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines. Link to comment Share on other sites More sharing options...
Torres Posted July 7, 2012 Report Share Posted July 7, 2012 eyeballing off the pictures on how much of the port is not in the box, i'm getting a tuning of 32 hz. that's before any displacements. Link to comment Share on other sites More sharing options...
16K Posted July 7, 2012 Report Share Posted July 7, 2012 my question is how do u find out how long that port is.... since its L shaped.... im thinking like 18"... and if thats the case its tuned to 24hz.... that box is too big for 2 12s imo http://portsgalore.stefanhinote.com/?do=portlength *** 1991 Turbo Walled Civic 400whp @ 20psi *** - JVC KDS88BT Headunit - 4 15" Fi BTL N2 Fully Loaded Subs - 1 SD16kD Amp - 14.5ft^3 Wall Tuned to 37hz with 202in^2 of port - Mechman 220a HO Alternator - 6 XS Power D3100 Batteries - Copper Buss bars - 2 Runs of 4/0 Welding Cable - Big 3 - Stinger Digital Volt Meter Burp outlaw in the kick: 158.9db Music: 157.5db Sealed on the dash: 157db - SPL Labs Rep for Missouri - Link to comment Share on other sites More sharing options...
Torres Posted July 7, 2012 Report Share Posted July 7, 2012 measure down the middle, and yes i got 18". but how do you figure 24 hz? Link to comment Share on other sites More sharing options...
16K Posted July 7, 2012 Report Share Posted July 7, 2012 thought it was down the middle use my calc lol http://portsgalore.stefanhinote.com/?do=portlength port is 6" x 6" since you take off 3/4" on each side i got around 7.5 ft3 after subs.... type in 24hz for the tuning.... it shows it needs to be 17.7" long *** 1991 Turbo Walled Civic 400whp @ 20psi *** - JVC KDS88BT Headunit - 4 15" Fi BTL N2 Fully Loaded Subs - 1 SD16kD Amp - 14.5ft^3 Wall Tuned to 37hz with 202in^2 of port - Mechman 220a HO Alternator - 6 XS Power D3100 Batteries - Copper Buss bars - 2 Runs of 4/0 Welding Cable - Big 3 - Stinger Digital Volt Meter Burp outlaw in the kick: 158.9db Music: 157.5db Sealed on the dash: 157db - SPL Labs Rep for Missouri - Link to comment Share on other sites More sharing options...
Torres Posted July 7, 2012 Report Share Posted July 7, 2012 are you accounting for the amount of port that is not inside the box? Link to comment Share on other sites More sharing options...
bkolfo4 Posted July 7, 2012 Report Share Posted July 7, 2012 Both of you guys missed his mistake - The 12 dimension should be 13.5 (7.5 + 6). This gives a port length of 19.5, not 18. And how did 16k get 7.5 cuft?? 25.5 x 32.5 x 13.5 is only 6.47 cuft gross volume. Maybe I missed something?? Guessing on the amount of port sticking out of the box, and guessing on the amount of flange protruding into the box for the pieces to connected the 2 pieces of box together, you are very close to 5.5 cuft tuned to 27 Hz. Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
