Calculating Gain Voltage?
doughboi916
according to the JL tutorial they said 1khz for midranges... and 50hz for woofers...
Like he said 1khz.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
  • 4 weeks later...
Posted Image
forgot who originally posted it but i saved it ;)
i am a bit confused cus in that table it says that if i want 800rms @2 OHMs then i need 40 volts. but the calculation to achieve this is ....square root 800x2 correct? which if it is then i need 56 volts.
but that table says that is 4 ohms? someone explain lol.
cheeeers.
x
*Alpine Typr-R 12"
*JBL GTO 1200.1 Sub Amp
*Alpine PDX-4.100
*Rockford Fosgate Power 6.5's
*Rockford Fosgate Fanatics 6.5's Both in front doors
*0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator)
*140 Amp HO Alternator
*Alpine Head Unit
-------------------------------------------------------------------------x------------------------------------------------------------------------------
Be a man and learn how to do it by ear.
If your useing it with mids and tweets you would almost be an idiot not to beable to do it by ear.
Subwoofers are the hard part to do by ear.
You can do it man just take your time, find some good quality recordings (4 or 5 good CDs)
and when things start to sound crappy you know the amp is up to high.
Your ears won't lie.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
sorry but no!
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
cheeeers.
x
800 x 2 = 1600 square root of 1600 is 40 ;)
for 4 ohm
800 x 4 = 3200 square root of 3200 is 56.56
DC.jpgDC POWER
Because your amp puts out AC voltage. Have you ever seen ac and dc voltage on an o-scope? if so you would know why. If your sub is getting dc power its a very bad thing :wacko:
X2. Also DC doesn't move your subs. It only powers the amp and then the amp converts it to AC.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
for 4 ohm
cheers man, that has cleared it up tonnes !!!!
i put square root 800x2= (in that order and it was giving me 56) but putting800x2=1600.......then square rooting 1600 gave me the 40:)
thanks!!
xx
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
lol at the things in the quote box :S haha
*Alpine Typr-R 12"
*Alpine PDX-4.100
*Alpine Head Unit
  • 3 weeks later...
on iTunes, if you search 50 hz the first couple come up as bass mechankik ..... could i use one of these or would i have to find an actual CD and nto burn my own?
Thanks; sorry for bumbin an old topik :)
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
Nothing wrong with the Bass Mekanik 50hz tones. Just make sure they're the 0db reference ones.... which I'm pretty sure they all are :D
You can just download them from RoE and about 100 other places on the net you know...
10.x volts fo' life!
