they can handle more power than it says.....
How much would you say?
I've been wondering the same thing, how much power will these REALLY handle?
woman..cant live with em...cant shoot em...guess were all fucked
You might be a Redneck if you use your leftover gutters for a speaker box port...
YOU JUST LOST THE GAMER.I.P. Blazer=========================Last setup was in the 141s on music (37hz) with 2 12s and 1kw in a 4dr blazer.2010 Mitsubishi Lancer DE2 12in Clarions (kept from blazer)HiFonics BRZ1700.1d (at 2 ohms BLOWN) [JBL GTS180X for subs currently 60wRMS x2ch!!!!!! This works for till i get the blown amp fixed] Alpine 4ch salvaged from blazer (currently near death)9887 peerless 7s in the doors and CDT tweeters ran active no speakers in the rearKintik HC1400 under the hood.metered once a while ago, dont remember it...was piss poor compared to the blazer, mid 130s i think....looking to replace subs and amp when i have money.
so then which would you recommend?
d2 can be wired to 2ohm or half ohm-d4 can be wired to 4ohm or 1ohm
so it all depends on what your amp is stable at.
i wouldnt put more then 1000rms to em
d2 cannot be wired to 2 ohm, its 4 or 1, D4 is 2 or 8...for single subs... if you're running 2, then D2 gives you 1/2, 2 or 8 ohm. D4 gives you 1, 4 or 16.
if you are curious on how to wire different subs with a d2 or d4 voice soils go check out
www.the12volt.com it will tell you everything you need to know
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
  • Who's Online   0 Members, 0 Anonymous, 1390 Guests (See full list)
