Amp Power Consumption vs Ohms Question
So my question is. I have an American Bass HD 3500. It is 1600rms at 1 ohm, and It doesn't say what it is at 2 Ohms but let's say around 800. Right now with a 2ohm load i see 13.15 volts at full tilt. by going to 1 ohm, will it consume more power creating worse voltage drop, or will it pull the same power, but because there is less resistance the sub gets more power?? I think i worded this correcting haha
simple ohms law will give you your answer
as impedence lowers current draw rises in a nutshell.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
where the hell did you get that out of what i said.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
lol im not sure i guess. . . read it kinda quickly. i know as ohms drop current rises, which is the whole point of running lower ohms. but did you mean current draw on my amp from battery and such increase as well?
answered, ninja'd. thanks guys!
Edited by Mikey Bates
Current is supplied from the battery and the alternator.
If you increase current draw and have a resistance factor or not enough current supply you will cause voltage to dip which has the visual effect of dimming your lights.
If you're using 100 amps of power it comes from somewhere, you cant just increase the power draw and expect your supply system to cope magically.
edit
Also, you can not increase power ouput without increaseing power draw (amps)... unless you get a more efficient amp, but the general rule is no power ouput increase without power input increase.
Edited by STEvil
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 1686 Guests (See full list)
