Mikey Bates Posted July 9, 2012 Report Share Posted July 9, 2012 So my question is. I have an American Bass HD 3500. It is 1600rms at 1 ohm, and It doesn't say what it is at 2 Ohms but let's say around 800. Right now with a 2ohm load i see 13.15 volts at full tilt. by going to 1 ohm, will it consume more power creating worse voltage drop, or will it pull the same power, but because there is less resistance the sub gets more power?? I think i worded this correcting haha Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted July 9, 2012 Report Share Posted July 9, 2012 simple ohms law will give you your answer as impedence lowers current draw rises in a nutshell. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Mikey Bates Posted July 9, 2012 Author Report Share Posted July 9, 2012 So dimming and voltage drop should stay the same? (i figured this as i know the ohm laws give or take just wanted second opinion) Quote Link to comment Share on other sites More sharing options...
n8ball2013 Posted July 9, 2012 Report Share Posted July 9, 2012 where the hell did you get that out of what i said. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
Shankkilla420 Posted July 9, 2012 Report Share Posted July 9, 2012 No >< when your drawing more current that equals more power.. Quote Link to comment Share on other sites More sharing options...
NT_Hardcore Posted July 9, 2012 Report Share Posted July 9, 2012 (edited) the lower the imp the worse it will be on your elec. so lights will get dimmer. Edited July 9, 2012 by NT_Hardcore Quote Link to comment Share on other sites More sharing options...
Mikey Bates Posted July 9, 2012 Author Report Share Posted July 9, 2012 (edited) lol im not sure i guess. . . read it kinda quickly. i know as ohms drop current rises, which is the whole point of running lower ohms. but did you mean current draw on my amp from battery and such increase as well? answered, ninja'd. thanks guys! Edited July 9, 2012 by Mikey Bates Quote Link to comment Share on other sites More sharing options...
STEvil Posted July 11, 2012 Report Share Posted July 11, 2012 (edited) Current is supplied from the battery and the alternator. If you increase current draw and have a resistance factor or not enough current supply you will cause voltage to dip which has the visual effect of dimming your lights. If you're using 100 amps of power it comes from somewhere, you cant just increase the power draw and expect your supply system to cope magically. edit Also, you can not increase power ouput without increaseing power draw (amps)... unless you get a more efficient amp, but the general rule is no power ouput increase without power input increase. Edited July 12, 2012 by STEvil Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed. Link to comment Share on other sites More sharing options...
bassface Posted July 11, 2012 Report Share Posted July 11, 2012 It wont be 800 at 2 ohms, probably like 1200 Quote Link to comment Share on other sites More sharing options...
andale927 Posted July 12, 2012 Report Share Posted July 12, 2012 Yeah, you will definitely at least double current draw Quote Link to comment Share on other sites More sharing options...
